TwinTurbo.NET: Nissan 300ZX forum - A Bad CAS will prevent Spark and Fuel..
Cjw3
on March 23, 2019 at 1:23 PM
Re: It won't be the CAS.. But it might be a PTU or wiring
posted by BannonZ
on March 23, 2019 at 12:53 PM
Or a CAS that is falling apart will cause Irratic running, As the Ignition and Fuel Systems will be getting Irratic Readings.. Your Car run fine after starting..
Cj
Potential PTU issue, would like some input
BannonZ
08:20:09 03/23/19
Please bring me up to speed
Cjw3
09:23:03 03/23/19
Thanks
BannonZ
10:44:25 03/23/19
So you have Fuel pressure before you spray Starting fluid? (n/m)
Cjw3
11:45:30 03/23/19
Will it then restart without Starting Fluid? (n/m)
Cjw3
11:49:23 03/23/19
Yes
BannonZ
12:00:17 03/23/19
Sounds like you exhausted the Fuel Issue
Cjw3
12:17:22 03/23/19
All tested above spec.
BannonZ
12:20:50 03/23/19
It won't be the CAS.. But it might be a PTU or wiring (n/m)
Cjw3
12:51:49 03/23/19
BannonZ
12:53:10 03/23/19
A Bad CAS will prevent Spark and Fuel.. -
Cjw3
13:23:02 03/23/19
Update, I tested as CJW3 suggested, pins at the #6,5,4
BannonZ
10:56:49 03/29/19
So, replace the friggin PTU and report back. We are
jzack
23:27:02 03/23/19
lol, I'm on it. A friend is supposed to bring one over today
BannonZ
08:16:00 03/24/19
'Direct Wire' is the way to go
FrozTTy
13:26:40 03/25/19
My PTU is on the way for tomorrow. I was thinking about
BannonZ
13:54:55 03/25/19
Exactly! :-) (n/m)
jzack
23:49:55 03/25/19
Sorry, forgot to add. The idea is to make sure there’s
jzack
23:59:25 03/25/19
Update, No Dice
BannonZ
06:45:22 03/28/19
I'm still waiting for the Cranking Voltage Numbers (n/m)
Cjw3
07:01:02 03/28/19
Haven't had anyone to help me yet this week.
BannonZ
07:12:20 03/28/19
Do to the fact that I found some corrosion on the 7
BannonZ
07:10:59 03/28/19
DUE (n/m)
BannonZ
13:14:55 03/28/19
